D
Deleted User
Guest
Welcome to GamerROM®11
Our newest release before 2018 is now available for download with new improvements from mistakes made in ctOS 10, this OS not only bring CPU & GPU to their max performance capabilities, without the cost of losing battery life.
This OS is remade from scratch to not only improve everyday gaming tasks, but simple ones a well, this year for 2018 we wanted to minimally take the OS to a new direction for the future giving not only performance but as well design and unique services that can bring your old S4 out of the box and be all in 1 multi entertainment device, also with ctOS 11 you'll be able to access our ctOS Network servers to play any game online with fast and secured services
Features:
IMPORTANT: We are only supporting the following model(s) at this time: SM-G930F (herolte)
NOTICE: You are soul responsible for any damages caused by this OS, this doesnt't mean our OS will break your device, this means if you screw up your device during the process of either but not limited to installing the OS improperly or installing 3rd Party applications that may alter the OS that is not compatible. We RECOMMEND that to not report bugs if the OS has been altered or tampered with by 3rd Party Applications that are not Pre-Installed by default. your are fully RESPONSIBLE for all damages caused by Installing & Using this OS, You can see the full agreement here for more info: http://www.ctosnetwork.xtgem.com/terms be aware that we can discontinue this OS or any services we provide 30 days after notice at anytime this includes services that may require ctOS Network Services to access.
NOTICE: CGS TV IS NO LONGER SUPPORTED AND NO LONGER IN BUILDS, THE BUILD CGS TV WAS REMOVED IN WAS V3.0!
OS Official Release Date: 4/10/2018
Download: https://mega.nz/#F!oFZXFZaS!phcFgv4A1W6HbW79LSMgcA
Features:
- ctOS®Network Enabled Game on the fastest gaming network
- More Secured to protect your privacy across multiple installed applications
- Optimized for Gaming & Daily Simple Tasks
- New Web kit Powered By: Google's Android System Webview for optimal browsing and application performance & security
- Optimal Fast Charging Enabled OS will help charge your phone to 50% or higher in 30 Mins or less
- Graphics Engine is Powered By Our All new Pure™ Graphics HD Engine to improve HD Quailty in intense games and applications
- Optimal Boot Times & Much MoreWhy Not give it a try something new will always bring gaming to the next level and closer of making life much simpler!
