zuben el genub
Extreme Android User
I posted this in the Nexus forum - no one has bothered to reply, so I'm reposting here.
I have an ad problem and want to back up before doing ANYTHING.
I just got a new laptop - windows 7 pro.
If I plug in the Nexus 4, I get all the files regardless if usb debugging is on or not. I can transfer some either way.
Try to back up all of it and all I get is "calculating time" nonsense and the computer just sits there and chews. I have no idea if it's doing anything or not. Somehow I don't think it should chew on a folder for 10 minutes and just say "Calculating"
I got everything copied on XP, dammit. In fact, the backup folder from XP in March is in the Documents file on 7.
The phone is rooted, but I don't have the Nexus tool kit on this laptop. Would it help?
__________________
Thanks
__________________
Thanks
