Help A big bad problem!
Fatality
I was backing up my rom using rom manager. It then rebooted phone into cwm and started the backup. After the backup was finished it rebooted again. Now i cant get past cwm into my android. Why? Can anyone help me? It boots only to cwm and not android
Update: I tried restoring my backup from cwm. but it shows md5 mismatch error. How can i solve this? Please help me i dont want a new rom or anything just be able to boot up into my phone like before!
Thanks
Have you tried the following from CWM:
1) Clear cache and dalvik. Won't do any harm, may help if something has been corrupted.
2) Restore the backup.
Now I don't know this phone at all, so you should take any of my suggestions with a little caution for that reason. But one one device I used to own CWM sometimes messed the system up the first time you made a backup, and the fix was to restore the backup. May be something entirely different here, and if someone who knows this phone has a suggestion follow that, but this may be worth trying if nothing better, or if you reach the point of flashing a new ROM instead.
Thanks for answering. I cleared the cache but get the same md5 error while restoring my backup.
