A Little Help!
  • Thread starter Thread starter allenmac
  • Start date Start date
A
allenmac
Guest
Hi all,
Im ready to customize my Dinc, with different themes and wanted to know how is the best way to tackle this..I have brought Beautiful wigets but not sure how to use all this..Any suggestions would be appreciated...Thanks
Well what do you want to do with Beautiful Widgets? You get the clock (obviously) which you can skin both the actual Clock and the Weather portion of the clock. BW also comes with other widgets such as Vibrate control and Silent control and so forth...If you want to go to vanilla Android you will have to root and load up a non-sense ROM. You can't do themes without being rooted (from my experience in Droid 1...not sure about dInc).
So, basically, if you are wanting to theme your phone then you will have to root.
Also, you can get MetaMorph (does this work on dInc? Only tried it on OG Droid) which themes certain aspects of the phone; however, I'm not quite sure if you have to have root or not. Others that respond will probably know more about MetaMorph than me lol.
