A Phone With Good Battery, WiFi Hotspot & Expandable Memory
jagillham
Hi all,
My current phone has kicked the bucket, and since getting my tablet I use it much less than I used to now anyway. So this time around my "needs" are maybe slightly odd!
Basically I am after spending the least amount I can on a phone that...
- Has very good battery life
- Can act as a wifi hotspot
- Has a memory card for my music
- Has a 3.5mm Audio Jack for headphones
So long as it has the web to check the news or whatever, no other features bother me anymore.
Anybody got any suggestions?
Thanks,
James
The Y's battery really isn't very good AFAIK (I got one free from my carrier and gave it away). Its at the lowest of the low for Samsung, and has a lot of apps incompatible for it due to screen resolution and low power. If an SIII is too expensive, try something like Ace 2 or Ace Plus
