A30 many issues
Hello,
I have an A30 and it was bought in Panama (IMEIs were changed there because they dont match the box) so anyways the phone is going giving me the following issues:
1) The phone shows as Custom in phone status, Magisk Manager is installed and developer options are enabled (OEM Unlocking, USB debugging, verify apps over USB, Multiple PBAP Properties)
I have to reboot the phone every few hours because it runs out of space, when I power it on it says 40Gb free but after a few hours it runs out of space and the only way to fix it is through a reboot.
The phone also shows IMEI status NG at times (when it doesnt register on the network I verify through *#0011# and it says NG but after a couple reboots IMEI status says OK and signal is ok as well.
What could be causing these two behaviors?
Priority #1 is the space thing which is driving me nuts.
