So apparently there is a bug in ICS that eats up battery life when you use the power button to shut the screen off instead of just letting it time out causing the OS to eat up battery life via "Keep Awake" under battery stats.
So my question is if I use the "Screen Off" widget will I end up with the same problem as I am using the physical power button? Kind of sucks that ICS has this issue. If it wasn't for this I would getting outstanding battery life from my MAXX.
