Help About the data transmission between the android phone and wear
carsonsu
Hi everyone,
I am working on sending the data from the wear(LG watch R) to the android phone. However, I can not find any mistakes on my code and I don't know how to test it.
Could anyone help me to fix it?
Thank you very much.
Here is the sending code of the wear:
@override
public void onSensorChanged(SensorEvent event) {
if (event.sensor.getType() == Sensor.TYPE_GYROSCOPE) {
value[0] = event.values[0];
value[1] = event.values[1];
value[2] = event.values[2];
xViewO.setText("Gyro X: " + value[0]);
yViewO.setText("Gyro Y: " + value[1]);
zViewO.setText("Gyro Z: " + value[2]);
if (event.sensor.getType() == Sensor.TYPE_ACCELEROMETER) {
xViewA.setText("Accel X: " + value[0]);
yViewA.setText("Accel Y: " + value[1]);
zViewA.setText("Accel Z: " + value[2]);
if (event.sensor.getType() == Sensor.TYPE_PRESSURE) {
pressure.setText("press: " +value[0]);
// TODO Auto-generated method stub
Log.d(TAG, "onsensorChanged" +value[0]+value[1]+value[2]);
sendToPhone(value);
private void sendToPhone(float[] value) {
Log.d("sendToPhone","sendToPhone");
PutDataMapRequest putDataMapReq = PutDataMapRequest.create(SENSOR_DATA_PATH);
putDataMapReq.getDataMap().putFloat(SENSOR_DATA_KEY,value[0] );
PutDataRequest putDataReq = putDataMapReq.asPutDataRequest();
Wearable.DataApi
.putDataItem(mGoogleApiClient, putDataReq).setResultCallback(new ResultCallback<DataApi.DataItemResult>(){
@override
public void onResult(DataItemResult result) {
if(result.getStatus().isSuccess()){
Log.e("phone", "success");
if (!mGoogleApiClient.isConnected()) {
Log.d(tag, "unconnected");
return;
Here is the receiving Code of the phone:
public class MainActivity extends Activity implements DataApi.DataListener, GoogleApiClient.ConnectionCallbacks, GoogleApiClient.OnConnectionFailedListener{
final String TAG = "sensors";
private GoogleApiClient mGoogleApiClient;
TextView wear=null;
private static final String SENSOR_DATA_PATH="/sensor-data";
private static final String SENSOR_DATA_KEY="sensor-data";
setContentView(R.layout.activity_main);
mGoogleApiClient = new GoogleApiClient.Builder(this)
.addApi(Wearable.API)
.addConnectionCallbacks(this)
.addOnConnectionFailedListener(this)
.build();
Wearable.DataApi.addListener(mGoogleApiClient, this);
mGoogleApiClient.connect();
wear=(TextView) findViewById(R.id.wear);
protected void onStart() {
super.onStart();
Log.d("start", "start.........");
@override
public void onConnected(Bundle connectionHint) {
wear.setText("test");
Log.d(TAG, "onConnected: " + connectionHint);
Log.d(TAG, "Connected to Google Api Service");
@override
protected void onResume() {
super.onStart();
// mGoogleApiClient.connect();
Log.d("Resume", "Resume..........");
public void onDataChanged(DataEventBuffer dataEvents) {
final List<DataEvent> events = FreezableUtils.freezeIterable(dataEvents);
dataEvents.close();
Log.d(TAG, "test");
for (DataEvent event : dataEvents) {
if (event.getType() == DataEvent.TYPE_DELETED) {
} else
if (event.getType() == DataEvent.TYPE_CHANGED) {
DataMap dataMap = DataMapItem.fromDataItem(event.getDataItem()).getDataMap();
if (event.getDataItem().getUri().getPath().equals(SENSOR_DATA_PATH)) {
String data = dataMap.get(SENSOR_DATA_KEY);
wear.setText(data);
