Ace help!!!
  • Start date Start date
A
Android Question
Guest
Ok so I bought my Samsung Glaxy Ace 2 3 day ago, and now I cant turn it on! WHat can i do!!!! PLEASE HELP, this is truly important!!!!!!!!!!!
Try charging via USB & AC, see if you get a response. Try pulling the battery too.
Do you have an alternative battery you can try?
If it's only 3 days old, your best bet would be to take it back to wherever you bought it from and seeing if they will give you a replacement.
