Acer Netbook and 3G USB problem
GlynLewis
Hi,
Brand new user to android o/s, so might be a real dumb question.
Just purchased new ascer netbook with dual Windows7/Android boot option. Boot to android is fine, connection to my wifi network works too. Only problem I have is getting android to recognise when I use my 3G USB modem (from Telstra - an australian telco).
When I go into the "manage networks" area, the 3G section is "disabled"?
Basically nothing happens when I just plug the USB stick in - no option to run a program, nothing.
BTW, the 3G USB modem works fine in Windows7, after download of a driver and a telstra front-end app that for network search/initialisation/connection dumb-dumb proof.
Puzzled? Am I supposed to use my HTC phone as a modem when "out of the office" with android?
Any advice/help most appreicated.
Regards,
Glyn
I am sorry, but I do not have an answer to your question. I do, however, have a question of my own. Do you have a link to the netbook you purchased? I am quite interested to see this netbook as, not only is a netbook that ships with android an oddity, but one that ships with BOTH Android AND Windows 7? Now that is a must see! I might even consider purchasing this--provided the price is right.
Hi Glyn,
Unfortunately the Telstra USB 3G modems only come with drivers for Windows (7/xp) and MAC OS, there are no Android drivers that I'm aware off.
Since Android is based on Linux hopefully somebody is developing drivers for USB 3G Modems!
A question for you - When you boot into Android are you able to connect to the Google Servers to sync your calander etc? I always get a "timeout connecting to google servers" message. I have an Acer Aspire One D260 Netbook.
Cheers.
Hi mimimoke,
That will explain it then. To be honest I have now switched the boot to android option off. It is the wife's netbook an she basically "just wants it to work" so ... she waits for windows 7 to bootup and then away she goes.
I'll have a look at the sync capabilities the next time I get the machine out of her handbag!
Slainte,
Glyn
Hi Johnbonazza,
Have not forgoteen about your question - jus trying to locate a web link for you that provides info because www.acer.com.au draws a blank, as does the retailer site www.jbhifi.com.au
I went into my local JB-Hifi shop and walked out with the machine and a usb microsoft mouse for $420 aussie dollars. I will post the machine details (retrieve machine this eekend form the wife), however when I looked at the Acer site the machine wasn't listed!
Also minimokes post, got a feeling my machine is also a D260.
Slainte,
Glyn
Hi Glyn,
I thought I got a bargin when I got the D260 from JB for $430, well done getting for $420 with a mouse !
Cheers
