Graham Brogab
Hi
I have a Sansung tab E (SM T560) and I have installed an SDcard. I have copied document and music file from my PC to the SD card. However all the applications I have tried to view this data fails because the Apps are unable to see the SDcard The Apps will not let me change the root directory. The Op system is Android 4.4.4.
If I use the file system to access the docs it states "no device to access this file"
Any ideas what the problem is would be helpful
grabro
grabro
