Twiz
Trying to do this part "Reboot into recovery mode. In recovery, flash the SU file you've downloaded earlier.
To do this, select install, then navigate to where you placed the file. Select the first file, then swipe to flash. "
There wasn't an install to select so I chose ADB update.. ummm NOw i'm stuck on the screen "Now send the package you wan to apply to the deivce with "adb sideload <filename>"
What do i do??!!
UPDATE: I tried typing in the command prompt to install the SU file. It said Daemon not running. starting it now on port 5037. Daemon stated successfully. error: device not found
I did get the phone to reboot normally. Still confused as to how to load SU.
I have no "install" selection. Only Reboot system now, apply update from ADB, wipe data/factory reset, and wipe cache partition are available selections.
What do i do??!!
