Adapter for Samsung Galaxy Note 10+
omairangel
Hi everyone, I just Pre-ordered my Samsung Galaxy Note 10+. T-Mobile. Looking forward to getting it! I have a question, since the phone does not come with a headphone jack (I'm disappointed), can anyone recommend an adapter where I can charge my phone and listen the music at the same time? Like a
USB C to 3.5mm Headphone Adapter, 2 in 1 Audio Adapter and Fast Charging Dongle Compatible for the the Note 10+ . Can anyone help please? Thank you.
You might consider an inductive charging plate. (wireless charging) You can then charge your new phone and use the oem usb connection for your earphones. Another work-a-round would be to stream your audio BT as you are charging via the usb port. Easy solutions. I don't know of a charging cable that has the headphone adapter that will work simultaneously though it may exist.
We are discussing the Note 10 and 10+ here if you'd like to join us. https://androidforums.com/devices/samsung-galaxy-note-10.16515/
