DonJones
I've downloaded the SDK platform tools with ADB and Fastboot included. When I issue command adb devices, it gives a fault error. I have downloaded all the updated usb drivers and installed them manually via device manager but ADB still will not connect properly. I've tried using different USB ports, and yes I have both USB debugging on. Ive also tried every option that appears when I connect my phone to the pc (i.e. File Transfer, PTP, use as MIDI, etc.) I'm running Windows 7 and have a Nexus 5x.
Any help is appreciated
Side note, I was able to successfully download and use ADB on a Windows 10 machine. I also have an unlocked bootloader and subsequently got stuck in a bootloop after flashing TWRP ( I think I neglected to unencrypt my phone prior to doing that). I had to flash a stock image from google to get back up and running.
