Apps ADB dont start....
NelsonBN
Hi,
I've been with some difficulty in setting up my development environment for Android...
After giving many turns to my settings, I think that I concluded that the problem is, i can not kick-start the "ADB" ...
I'm using debian 6, and I'm trying to boot the adb with the command line options "/opt/android_sdk/platform-tools/adb start-server" but this give me the following errors:
* daemon not running. starting it now on port 5037 *
cannot bind 'tcp:5037'
ADB server didn't ACK
* failed to start daemon *
I thought the problem was that I had some program using the port "5037" but I used the command "netstat" and found that I have no program to use that port ...
someone can tell me how can I solve this problem??
Thank you very much for your help!
