Ok, I've tried about 10 different tutorials involving step-by-step instructions to get adb functioning properly but I just can't get it to work....I'm so frustrated by now, that I can't even remember why I needed it...Anyways, I'm not one to give up, yet I do need help....Here's what I've done so far:
Downloaded SDK
Downloaded Eclipse
Downloaded USB Drivers via SDK and AVD Manager
Added the correct folder location in my PATH....I used this tutorial(http://forum.xda-developers.com/showthread.php?t=502010) and placed it in it's own variable named "adb" since "path" wasn't working either.
This is the location: C:\android-sdk_r04-windows\android-sdk-windows\tools
When I run the cmds up to here:
C:\Users\My Username> cd C:\android-sdk_r04-windows\android-sdk-windows\tools
C:\android-sdk_r04-windows\android-sdk-windows\tools>
And then I give cmd "adb devices" it just comes back with "devices list attached" and it's blank...So I think there is an issue involved with the whole updating of the drivers because when I go into device manager and point to the proper folder, windows comes back and says that the driver is already up to date so it never installs it. I also uninstalled the drivers and then reinstalled them using the same procedure and nothing seems to be working.....I'm on a Vista 32 Bit with a G1....Any help would be great, I believe I have inputted all information needed for you guys!
Thanks in advance!
Brandon
Downloaded SDK
Downloaded Eclipse
Thanks in advance!
Brandon
