hiitsme0819
hi im kind of a noob i had the ascend by metro and rooted no prob and the sidekick tmobile i rooted no problem however i just bought the mytouch 4g a week ago stock 2.3.4 been trying the down grade method and every command i put in says adb permissions denied ive installed adb from two different guides now and search every forum i can find if anyone can give me a hand with this it would be amazing
update
i now know for a fact adb is installed correctly i hooked up my old ascend from metro and the adb comands run on that phone no problem
solved
okay I figured it out what is anything that I was doing wrong some of the commands won't work on stock 2.3 .4 when I get home around my computer I'll type up a guide to help people out that have the same problem as me
update
solved
