El Presidente Beware The Milky Pirate! VIP Member Mar 3, 2015 #2 I presume you've enabled USB Debugging? Also, if Sony's PC Companion is running in the background, disable/kill that and try again.
EarlyMon The PearlyMon VIP Member Mar 3, 2015 #3 What? Is the system up and running with USB debugging turned on? Does "adb devices" return the serial number or nothing? If nothing, you're likely missing the adb drivers.
