FluffyFox20
Haii, This is confirmed to work on Kitkat, but there is no recents key. I know how to change that.
Nexus Status Bar: Thanks to Biggiephil :3
What you will need:
Build.prop editor
Xposed Module
G2 Xposed ( Works on L70)
1. GO into Build.Prop editor and add:
qemu.hw.mainkeys=0
2. BEFORE YOU REBOOT, Go install G2 XPOSED ( Is available on the play store) and then reboot.
3. WHEN phone is booted, you will have the softkeys. Now go into G2 Xposed and then " Navigation Bar " then Slide the switch to ON.
4. Change Number of buttons to 3, and make the menu key to recents.
For Nexus Status Bar: GO into Status Bar in G2 Xposed and check KITKAT theme status bar then reboot.
Screen shot:
What you will need:
Build.prop editor
Xposed Module
qemu.hw.mainkeys=0
Screen shot:
