hey where can i find adobe flash player for my phone??
im using huawei sonic u8650 and it has android gingerbread(2.3.3)
i dont have adobe flash player in my android market when i search for it!!
so where can i donwload adobe flash player??
Your phone has an older ARM6-based CPU (the Qualcomm MSM7227), which isn't supported by Adobe. Adobe only supported ARM7-based CPUs or newer. You won't find the Adobe Flash player on the Android Market because the Market only shows you apps that you can actually run. (I have the same problem.)
However, there is an independent team that ported the Adobe Flash Player v. 10.2 for ARM v6 processors. It seems to get good reviews (and some custom ROM makers have even built it into their ROMs) but I haven't tried it yet because I don't really care much about Flash. (I care a bit, but I figure I'll install it if I ever need Flash.) You can download and install it from the following link. (Make sure to skip past any advertisement screen after hitting the download link.) Adobe Flash Player 10.2 For ARMv6 and ARMv7 Android Phones | Android Campus
