Help Adobe Flash Player not working
bencurt24
hey yall, I was curious if anyone had experienced the problem of not being able to play videos on a website. Before i installed 2.3.6 i could go to accuweather and play videos on their website but now when i go to accuweather it says i need to update my flash player and when i click on the update flash player on the website it goes right to the app store and tell me to download adobe flash player 11 but it never loads all the way.
Does anyone know of this problem or have any solutions to this problem?
Thanks
i have a problem on my LG Thrill with flash. Just uninstall the last update and things should work just as before.
I'm also trying to figure this out right now...
there must be a problem with the newest version of flash player. I flashed a nandroid of xplode ROM and the same videos i tested are playing fine now. Maybe try uninstalling the updates. The version I'm using with this rom is 11.1
