Advance Task Killer and Kakao
fran33s
Does Kakaotalk work with Advanced Task Killer? I know WhatsApp doesnt and they make you uninstall any apps that are task killers. Does Kakao do the same thing right now? I uninstalled task killer but i feel i get better battery life when i have it on and on autokill. so will it work?
But he feels better about it despite the contrary evidence. Don't disregard the placebo effect.
Kakao talk's service should auto restart as well if it is killed unless you set it not to in the settings.
Nothing works with Advanced Task Killer. The point of Advanced Task Killer is to kill apps prematurely, either because they need to be running or because they only appear to be "running" and are actually just cached, and thus will just restart on their own anyway.
Ditch ATK and just use your phone the way it's intended.
