Bodycount
Need some help with any smart action guru's out there.
Here's the deal. I have three smart actions.
1.) Turns on when I'm home and my phone detects my wireless connection.
2.) Turns on when I'm at work and my phone detects my works wireless connection
3.) Turns on when I'm in my car when my phone detects my car bluetooth.
I have #3 set to open an app called "DailyRoads Voyager". It's an app that records your driving. Basically so if I ever get into a crash in front of me, it's recorded for the police and/or my insurance company. There's some other minor stuff that's changed with this smart action but the app is the main goal of it.
There is no smart action to close an app. I want #1 and #2 set to close DailyRoads Voyager so it's not running when I'm at home or at work. Obviously so it doesn't drain my battery.
I looked into various task killer apps but could not find one that would open up, kill an app, then close itself down. Because I would just set that up in #1 and #2 to open up, kill DailyRoads, then shut down and all would be good.
The app itself doesn't have an option to close itself down either when it notices wifi or a GPS location.
How would I go about doing this?
*correction: It does have an auto shutdown but only when used with the razr car dock. I don't use the dock. I use a rosewill dash phone mount which was much cheaper. Anyone know of a car dock stand alone app? Someone made one for the home dock which I use with a cheap phone stand on my desk. Can't find one for the car dock though.
