B
Blross88
Guest
This is useful. I really appreciate a free app like this app. I downloaded hadnscent the free sms app that allows you to change the color of the income and outcome bubbles but there are times that it acts up and I have to force close. Well after the force close occurs I cant access any of my text and thefore all my messages have been deleted. I started to just use the task manager after one force close on handscent and then it prevents the deleting of my messages. I do not know if the task manager is truly to answer to my problms with handscent but it does seem to make thediferent use of my different apps run smoothly. I strongly encourage people to download it because it may be helpful depending on what one is searching for.
