X X.droid.X Guest Jul 1, 2010 #1 Can you set your advanced task killer to automatically kill apps that you haven't used for a certain amount of time? for example 10 minutes? thanks
H h0odlam Member Jul 1, 2010 #2 settings, auto kill level set to either disable, safe aggressive, crazy
