Wise
Member
Do you use your android phone all day every day? Battery life not quite what you would like? Well the problem is android os has the ability to multi task. There for it leaves a lot of programs open in the back ground that can not only reduce perfomance. It can also put a major hamper on your battery life.
There are a lot of Task Killing applications out there. And i have tried a few. But i do have to say that ATM is the best one i have used by far.
With ATM You can easily kill all the back ground apps that are running with simply one click. And if you do have some apps that you dont want to end. FaceBook, Pandora, Email you can simply exclude them from being killed. I myself have the widget on every homescreen i have. With out a task manager application the only way to end out the running apps is to go to
Settings
Settings
