Thanks! I will check XDA right now72x72 works well also and gives a pretty nice resolution and the icons are not real big. The dock is really not that customizable but I don't mine because I like using five icons. XDA has alot of nice icon packs that you can modify or just use. I download them onto my PC and then usually modify them or just put them in my dropbox.
Also once I have said icons, do I just drop them onto my sd card, and then when I go to "custom shortcuts" they will availiable? Or they will just be in the gallery?
Basically once I download the pack form XDA how do I use them
HarvesterX™;2194918 said:Just an update but whoever is subscribed to this might want to know in case they don't already. The latest update of ADW EX allows for custom docks. Not sure if the free ADW launcher had an update for this though.
how would someone go about getting/creating a custom dock, I noticed that I could get background off of the hidden dock, but I would love to have a cool custom dock like the Laucnher pro guys do
These LP docks can be used in ADW EX
Most Recent Docks | LauncherPro Icons
