Hi Guys,
Downloaded the ADW launcher and I LOVE it.
ONLY thing that I need help with is how do you customise the little Horizontal drawer at the bottom of the screen. (Think its call the Dockbar?)
You can have a left hand and right hand button, but you can either have it on or off. Left button is dialler, right hand button looks like a direct dial button.
Under UI settings it says its customisable but cannot figure out how... Would like to change the RH button to something other than the direct dial it seems to be stuck on.
Any ideas?
Thanks a mil,
Lee
Any ideas?
Thanks a mil,
Lee
