ADW Launcher Problem
candi3188
Member
One of the reasons I started using ADW Launcher was because of the ability to rotate the homescreens on my Epic. I installed it yesterday and absolutely loved it, now it won't rotate into landscape mode. Has this happened to anyone? Any suggestions?
Did you check your settings?
You might have accidently unchecked the rotate box.
Go into System Preferences and uncheck System persistent. Then check the Home Orientation and make sure it says Auto/ sensor.
Do NOT recheck System persistent. See if that fixes your problem.
Glad that worked. ADW is a wonderful launcher but it takes a while to learn your way around it. Don't forget to backup your settings and desktop configuration once you get everything just how you like it. You do that through ADW settings - Backup and restore. It will save you time should you root your phone or change your ROM.
I have a problem with ADW. I don't know what I did, but I accidentally clicked on something that enabled me to change the homescreen layout where I can move the screens around. Like instead of having it1, 2, 3, 4, 5; it's now, 2,1,3,4,5. I tried going into the ADW's setting and find the damn option but I can't for the life of me find it. :<
hit menu and then "edit" should appear, that will allow you to shuffle homescreens.
Of course there's another option that's not in the ADW Setting -_-;;
Thanks :) That was driving me nuts...didn't even realize there was the Edit under the menu.
