aHome 311 for Android 1.6 or 2.0 or 2.1 !?
UFTrance
Hi
I recently bought the
(aHome 311 for Android 1.6 or 2.0 or 2.1)
Installed it whit succes and got it working, looks nice and seems to have loads of options.
I do have a few qustions though:
I) On each page you make, there is like an edge both on top and at the bottom (black) if any of your widgets goes into these edges, it's like they hangh on there and stays there, even when you turn page, it likes blures out..
Any way to remove these edges ?
II) I found these (Icon Packs) on market.
To use them, it says you need either (Better Cut or aHome "Full Version) But i cant get them to work, still tells me that i need one of those apps to be able to run them, even though i have aHome full version installed.. ?
Anyone knowes what i could do to correct this, would be very helpfull ;)
Kind Regards
UFTrance
