Help Ainol Novo 7 Venus No wifi
Just as the title suggests, after some use, my wifi on my tablet stopped working, when I try to turn it on in settings, it says "Turning Wi-Fi on..." and just sits there. I'm really confused.
Some other people have this problem too. I have read that disabling all the Chinese apps and rebooting fixes it. Otherwise you could upgrade to the latest version of firmware.
Newsmy NM785QC is a quad core tablet with MTK6589 chip, it is built in 3G, which become one of the most attractive selling points.
Here's the specifications as bellowed:
Selling points
Built-in 3G, voice and data, GSM/WCDMA option
MTK 6589 quad-core A7 CPU, up to 1.2GHz
7.85 inch 1024*768 TFT display with capacitive flat touch panel
Multimedia, entertainment, communication at will
Simple and fashion design for high quality life
Specifications
OS: Android 4.1
CPU: MTK6589 quad core
RAM: 1GB
ROM: 4GB
3G: Built in 3G,supports GSM 850/900/1800/1900MHz WCDMA 2100MHz (850MHz is optional) Others Supports BT/FM/GPS/WIFI 4in1
Display: 7.85"
Resolution: 768*1024
TOUCH PANEL: G+G
Speaker: 8Ω/1W AAC Hi-Fi speaker*1 Customization
MIC: built in MIC
WIFI: Supports IEEE 802.11b/g/n, BTV4.0
Language: supports for multiple languages
G-Sensor: Three axle G-Sensor
Camera: Front 0.3 M/ 2M, Rear 2M/5M
Battery: 3.7V 4000 mAh Lithium battery (4400,4800MAH is optional)
Using time: about 5 hours when WIFI is working
Power adapter: Input: AC100-240V.50-60HZ, Out put: DC5V 1.2A
