Air Playit: No longer updated?
You might want to contact the company if the link to their product is broken on the site, tell them to fix it. There are plenty of other media streaming apps for Android, can't recommend any particular one though because I don't use them.
It can still be downloaded at Air Playit - Streaming Video to Android 0.9 Beta free download - Software reviews, downloads, news, free trials, freeware and full commercial software - Downloadcrew but, as Mike said, either the link is broken and they'll want to fix it or they just gave up interest in the product and the site will stay up until the hosting company doesn't get paid and takes it down.
Thanks, but I don't know if I can trust that website..
I just bought Plex, but I'm not sure on how to use it. Any tips?
is there some reason for this addiction to the most recent version i am unaware of? i hardly updates any apps that work properly (updates can change the UI to something i might dislike, uses more space on the internal storage, might break things) and fail to see the point.
for that same reason i no longer care if i'm even on the most recent version of Android.
