Help Airplane mode help
KB12
What program is it that turns on airplane mode all night long?
I have Tit. Backup, SetCPU, and used to have juice defender (but uninstalled). For the business I do, I've got to be able to receive anything all night.
Every night my airplane mode comes on and I don't know what program to go to to fix it...
After doing a search through a PDF of the manual and looking for both "airplane" and "schedule" nothing came up for enabling Airplane Mode automatically.
Like stef7 said, you must have installed some app with that capability.
Maybe you're just sleep phoning. :rolleyes:
Juice Defender can put your phone into airplane mode at set times. I'm using it now and it turns my phone radios off/on in accordance with my sched. I think the free version will do the airplane mode, but caveat emptor, I have the 'ultimate' app with all the options available to me.
I'm using Juice Defender Ultimate, and there's an option for night mode, which lets you select an timeframe to have the phone shut down the radios like MrB206 described above.
JD works great, but it keeps silencing my notifications when it puts the phone into airplane, even though I don't have 'silence' selected for the time frame. Kinda puzzling.
Thanks guys. Had too much fun trying to get better battery life that I forgot one extra program was installed. It was a combo of JDS and Go Power Master (from Go Widget).
