Airplane mode
Settings - Airplane mode
check whether the option is really enabled.
On most mobile devices especially Android if Airplane Mode is enabled there should be a small airplane icon in the taskbar and when it's not enabled you won't see it. That's just a little something that the developers implemented to its devices to let users know their device is not communicating by adding that icon to the taskbar when Airplane Mode is enabled.
And another way you will know your Airplane Mode is enabled is when your device browser doesn't work.
Unless the WiFi is turned on and it's connected that way? WiFi can still be turned on independently in flight mode .
Unfortunately every device have had when I turn airplane mode on no communication comes through not even Wi-Fi but maybe that functions vary from device to device.
Well I know WiFi definitely works when the phone is in flight mode...like when I was in a Boeing 777 at 36,000 ft above Siberia.... :D
Although may not get internet access until one spends the bucks.
Yes I've seen that on some devices but what I was indicating is the ones I use when airplane mode is enabled no communication comes in or out because of my mobile Banking endeavors.
I think it should work and have full internet communications via WiFi only, including banking endeavours. After all it's not only flight mode, many Android devices just don't have cellular 3G or 4G in them.
From what I've encountered, enabling Airplane mode does disable all online connectivity effectively. But one can still then selectively re-enable something like WiFi on it's own, still leaving everything else as is.
Sorry, something went wrong.
A team of highly trained monkeys has been dispatched to deal with this situation.
If you see them, send them this information as text (screenshots frighten them):
APkpgMWho_wMVrCXAEwqF7zGRGe4xIqa6iVnYn0inTMn2XyX2bFLhoZA
aogWz7Sn396-lJGI9S5YpuBqJxORsRkGH_xehxJ5xccwQtQ1AYPfNOur
2Ef-rpjffHnyAl6Nu-IawaSsaIGI8Y4BhXMnqsmhoLynQzLe9s42nOCp
AsoRfXEN2_RihEcO6QnS8za5_wd70008Vq8Q8E-ERsPDPGWRD1CscZhF
6mHskrbFQS2GZTjKRnS9-4Eh_eh_EWNUrxngVOs7CWCeEoN0PIzMCmXG
rUxrfh8FTviarkBujqxDjyUmP72knc3pSC2INOjo14uCrV8MLcXCLY7A
qhggD36k46eiYgryNwUXTlQfUAtR7fSrasj6TDnMuj65CynAA6RJpXn1
oynkcmqQ96G4JEefX0SSE2cipGW6vT4O6gmxelWBGxyCqvYsXv3raf-l
IQly8twh1-78fnloZXtVRswO6EoLnw3NgYsxEM8HjROFchzlAQsqvlFQ
s9Y45Jk8MEo0Oq_bLfMi7sOU3PNchJmM0g1D3VeTr0FgG8XiCQeEuuBC
y0MtvYIAxm65KP_3O4Kk_80tAmjGSTp0iJF-i4l5eptPseMzx40otH54
Muit2nmd9YA8w692_sG1zq2JLwrRKnLA5AGYnMbXdWC6HRh_lApSzMZs
XdRAIYgf9t9z2yy5N41Rh1rDFSKtXuBuFUgIz-44XpSzGjYpdujku9TN
D6wbCXmC3laR7--hSXpyikhh8_FX2P7CuYWIdW_n0_29MlUzwtynZ3eR
FnHy-5eE-E_KsbRVoXzweOdcrlrd1Cy3mrg-okB1uv5Q6tD9aktofhRL
uh_tn7Z7YggA3101DOiQNIf16fvgJ4wPSZf8DCPyU8_nb_kA2_UCTKJe
RgpgrDc3XM4d-_oOuo76BxX0pnk1lUqKTyDBB8paBDar4f5Bl1TFwopL
ytFc0OcYWkzzXyZC2mzJ3xDO1WPQnquffKTmkDVPmctUZEzxY0sZBKkd
zr-GDMX8Ux_4TaPkAJ_JoHMi81ohP9KfLVVbodAQf10mtx5uOwNn3mXe
mvx1W_r_PwGXMMsszJCoPp6FHzF2G7HWhIl3RvbtHDL8cAXSPRBqBUSD
9vO3D80mHz5rZVjHIdDeXiv4yKHoFjtSrO0hd_AFdVE5wVHaZLt0nzLh
OJFuUc964UtjgpZhxTVpfb9xJbolbLTN0PGhh9MYFEds6CH9sRjGz7jH
XcYgbc5yKg6GZLx1t-9G63JsrdwbMaHeE_03J1U1lKss_Vlv5FfULJ-F
Z7nRLnVica8kQ3T69L-M7aS-c0n_ox0LENqIYukpOWZFfGEdbpjfySjE
m2p19PBp8kCIa7f6CMBsg7c_7NPb-sptgTIfjdunqP3AH6xi_zzu3f4D
MCWDqj-nDHLTELMXFMRXI6wROpsUK1cTFHLQCaZN8h7LtXPn1CTAOumT
8JRzvOhbP6Z6EBOShHBvTzAZswNk3G75D4HxRrTzGNJrla1iMfsOOVt6
NcH0YTnFMLcAvCulpJFkOwS6HjfmaQbsMqSyoGSYFsNjk8c0ZJ0HAY39
pzN1mpxDNbcijQEqeZTDO7WOwvBKKG1nzJpiw6c-lFhTRS90LOAlpLxE
9691maT2Lwn7OXijiTYPdJ1bxScZy2eDs9Hjmzvu9uDnDQDT8CQn2OuE
Ro76z31tHKWxe2v9bGyDa703RL_-c2r0AeHWnXkmmJHNts6ufKoRZaeb
zgAjUZGoCst9NG9C90rZM4wgaVZ-A954TYJeyZYOD8QQqgGoOdtUfVDz
n-U9nzIcPqNwSIigQNQVa6PyZqx38T6T90K_9dE44oPneWY1aFR2u8t6
lUr0vBT6qN2YfDbwLayddWVk6PLUrHNvMQRh9YvS7yCdM6vyDJTZp_Tj
9lOthZ3p7RXXa_ouDcY6BTxQWaYTc_1PlTnsOoNxEDgHBG6zvzz8FqIG
W1pc24yQgBSpx-jkEJbYmPzM26DM46gLQNmdnTMNuycx_irFPEmR_9H7
RJsLS7cdCi-H_gwkF6LOaxkNTU-aJqNMtNpkgd0K1H5Z
