Why is my phone going into Airplane mode all of the time? We don't set it to do so...just seems to do so all on its own. I end up having to pull the battery and restart the phone...a big pain. Looking for some help, thanks!
I had the same problem, and ended up having to take my phone back to the store to have them find the answer.
Unfortunately, I don't recall what the solution was.
Have you tried a Factory Data Reset? You will find in under Settings > Privacy. It will delete all data on the phone. BACK UP! It will not affect things on your memory card.
