Hi there, I have the 2014 Galaxy Tab 10.1 which i use for my daily alarm in the morning, and i have it hooked up to external speakers. I'm noticing that when my alarm sounds it will only play through the internal speakers, and not through the external ones that are connected via the 3.5mm jack. I did try other alarm apps to see how they fared, but same result. If i play music through the tab it will play as expected, but alarms don't for some reason.
Does anyone have some solution for this, like is there an app i can use to force it to play externally? Thanks!
