Help Alarm clock snooze problem
Goatguy
I'm wondering if there's a way to change the settings on the alarm clock to lock the touch screen after touching it to "snooze". I'm paranoid that I'm going to end up dialing someone at 3:30 AM, since most people don't like being called at 3:30 AM!
Wouldn't worry about that. You need to enter the dialler first, or the green call button THEN choose from there. Normally the green call button will bring up the last screen you used it for ie: call list, or the dialler etc.
If you hit snooze, just leave it to lock itself, provided you have automatic screen lock set.
I set two alarms & the snooze being the same length inbetween.
