Help Alarm default volume
When I create a new alarm in the Android clock app, the default volume is too high. I've gone into settings in that app and under the Timer/Sound section, picked a new sound, and lowered the volume to the level I want. The new sound I chose is appearing as default when I create a new alarm, but the default volume is still way too loud - meaning I have to manually go into each new alarm lowering the volume or, more often than not, forget and get a noisy reminder the first time the alarm goes off.
How do I change the default alarm volume level, so that when I create a new alarm, its volume is set quiet by default?
You can also search for a setting (likely in the Clock app) that gradually increases the alarm volume.
This gives a few secons to react before the alarm reaches full volume.
I use this setting because I use a very loud alarm to insure that I get up in the morning.
