Help Alarm issues
Turbo1002
This is really annoying me, hopefully someone has a workaround for my issue. When commuting to work I use headphones plugged in to the 3.5aux jack on the phone. The music is turn down low so I can get some sleep. The alarm is set to wake me up when I get to work. With my old phone lg f6 I could have the music low and the alarm set high to wake me up and it did a great job. This phone the stylo is not doing this. It has different settings for volume. I can set the alarm to high when I program the time. The problem lies is the headphone setting. The alarm is not overriding the headphone volume. I can max out the alarm setting volume but the alarm sound is not any louder than the headphone aux out volume.
Like I mentioned before the lg f6 the alarm would override the music with the sound level programmed in the alarm setting. Hopefully I have explained myself well enough and there is someone who can help. I really need this feature. Thank you to everyone here for the help.
Thank you for the advice but the problem is still there with that app.
This happens when i have the headphones plugged in. There is a headphone volume setting which needs to be disabled or increased when the alarm goes off.
Hmm, I''m not sure. I have noticed when I plug the headphone jack into my Aux jack on my car stereo and turn the volume up, at a certain point it stops going up (before max) and gives a pop up warning about "loud headphones can damage your hearing". Maybe that is what is intercepting your volume increase and stopping it.
