Alcatel Phone (SD card)
  • Start date Start date
A
Android Question
Guest
My ALCATEL phone keep saying sd card removed i dont think i need a new one what should i do i reseted my phone nd it still say th same thing
Hi and welcome to these forums.
It could be a dirty card or bad connection. Take the card out, make sure the contacts are clean and put it back carefully. If no good, try someone elses card if you can to check that its not a faulty sim card.
Roger
