M Miguel Aleman Lurker Nov 26, 2015 #1 How do I connect my S6 to the Samsung Allshare Cast Wireless Hub using my Vizio Smart Tv?
P Pugs1957 Guest Nov 27, 2015 #2 These are instructions from Samsung Website Connect the wall charger to the power socket on the AllShare Cast Wireless Hub. The status indicator turns red after about three or four seconds. Connect an HDMI® cable to the AllShare Cast Wireless Hub and to an HDTV. Change the source input on your HDTV to match the input port being used by the HDMI cable. When the status indicator begins to blink red (this may take up to 30 seconds), press the Reset button. The status indicator should now appear blue. On your device, touch Apps > Settings > Connections > Screen Mirroring . Touch the slider to turn Screen Mirroring on . Select the AllShare Cast Wireless Hub from the list. The name will appear on your HDTV. Your device will now be connected, and your screen will be shared automatically.
