[ALPHA] [Unofficial] Orange Fox Recovery R11.0 for ZTE Avid Plus Z828
Code:
* Your warranty is now void.
* We're not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this recovery
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at us for messing up your device, we will laugh at you.
Working:
SD card access
Flashing
Brightness
Touch Screen
Everything else...
Not Working (Fixing Soon):
Backup to Data
Terminal
Internal Storage Access
Download
RS.1 - February 6 2021
https://roms.alexenferman.com/?/zte/achill/ofox
Installation
As this device is quite locked down from the factory, the installation process is a bit long, but is easy once you get used to it.
You will need:
Unlock the bootloader first: https://androidforums.com/threads/how-to-unlock-the-bootloader-of-the-zte-avid-plus-z828.1324697/
  • Download the "Files for QFIL" ZIP file and extract it to the desktop
  • Boot into Factory Test Mode (FTM) by pressing VOL- and POWER
  • Connect your Avid Plus to a PC
  • Using ADB commands, type "adb reboot edl"
  • Open QFIL
  • Select "Flat Build"
  • Click on "Load XML" and select the Patch0.xml and Rawprogram0.xml files from the desktop.
  • For the Programmer, click "Browse" and select the firehose called prog_emmc_firehose_8909.mbn
  • Rename the downloaded recovery to recovery.img, and make sure it is in the same folder as the Patch0 and other QFIL files.
  • Click on download.
  • Once done, remove and put back the battery and boot to TWRP using VOL+ and POWER
Contributors
@Alexenferman
ZTE (For providing me with the stock ROM after a month of E-Mails)
Device Sources
https://github.com/ZTE-Avid-Plus
Downloads
