Am I going crazy? Android Messages missing?
Hello everyone! I recently switched from my stock Samsung sms app to Android messages (which I love!) I did this because I wanted to try out the web version of Android messages. The problem is I am missing text messages my friends and family are sending me. Allow me to illustrate:
Me: Why didn't your respond to my test last night?
Friend: I did! I will show you on my phone!
Me: Well... sh*t.
Should I switch back to the stock Samsung texting app?
Thanks everyone!!
- Jon
Is Android Messages set as your default messaging app?
You can go into settings/apps/messages to check, set as the default if it isn't. While you are there go to the Samsung SMS one too, clear cache and force stop it.
You can also clear the default on the Samsung one, if it's set. That should prompt you to choose A.M. as default when you open it.
Clementine,
Thanks for responding. It was set as my default message app. I guess I was looking to see if anyone else was having the same issues? I just uninstalled it, which stinks because I really liked it. I use my phone for business and Android Messenger was making me paranoid.
Maybe it has bugs because it is still new (the web integration?)
Are they texting you from Iphones? I heard that the latest version of iMessage can "accidentally" lose messages to non-iPhones....
