My wife has just got the S3,Now looking at the wireless part of it if i click on the advance you get this:
Check if wifi internet service is available when ap connected
Now if you tick this then it will always use wifi if its there and not the mobile network?
Hi
Thanks for your reply yes i knew how to connect to wifi but what i would like to know is if i tick this: Check if wifi internet service is available when ap connected will the phone allways use wifi rather than the mobile data?
Not sure what ap means? is that mobile data?
what that tick will do is check if your ap or access point has internet access not needed and in some case will error even if you have internet access with the phone and ap.Hi
Check if wifi internet service is available when ap?
there is an always on option under advanced settings which will explain that.I am no expert have just started using my Samsung Galaxy S3. But I notice when using the mobil apps of a full web site they seem to run much faster then just using my phones service provider. Another item I notice if I turn off the phones WiFi the next time I look it's turned back on.![]()
Its for when she is out so it doesn't connect to the mobile internet even if there isn't wifi,Just so she doesn't use all of her limited interent use.
Wigfield - I am not sure who your service provider is, but mine is at&t and they have a smart wifi app that automatically connects to wifi when it is available, whether at home or out and about.Thank you to both of you i am aware about mobile data,That would be the last thing she would do as turning it off would mean no picture messages.
She has tried turning on wifi when she wasn't actually connected to a wifi network,But the mobile network still gets used untill you have a connection with a wifi network.
