Ambient Display Scheduling
Is there a way to set-up a schedule for the ambient? I think it's really convenient but I don't need it draining battery when I fall asleep and forget to shut it off.
Thanks
Nope, it's either on or off.
For what it's worth, I've found the battery drain to be very negligible. I wouldn't stress about it too much - though you may want to use the Send Feedback option from your device's Settings menu to let Google know that you'd appreciate a scheduling option.
Personally I went the other way: I decided I didn't need it always on, so set it so I could double-tap the screen to see it if I wanted it. I have the notification LED to tell me whether there is anything significant on there.
