Purringfaerie
Greetings everyone! I've had the S8 for about a year now.
I primarily use a Windows 7 desktop, within which iTunes doesn't work for some reason. I'm sure iTunes would make finding, downloading, and transferring podcasts to the device wonderfully easy, but alas.
So far I use the Clementine audio player to download podcasts. I then manually transfer the downloaded podcasts by dragging and dropping each file into the Music folder on my SD card. What happens is that a few of them are impossible to find within the Play Music app, if that happens at all. Infuriating, haha. Help.
Edit: Forgot to mention that I do have a Macbook, but I don't use it as often as I should.
