Andrew1974
Hi all,
Just registered on the forums as this issue is starting to drive me mad,
I purchased a tonbux android box from amazon, I still need to setup kodi and everything and it works fine, the problem I am facing is that when I connect the android box to the AV receiver it knows off the ARC (audio return channel) and my TV cannot see my amp, everything then just goes through the tv speakers.
They are all connected by HDMI
my setup is as follow samsung smart TV
onkyo tx-sr343 5.1 AV receiver
Sony BD player
SKU HD box
TonBux Andorid box running kitkat quad core, 1gb ram
if I disconnect the android box anytime CEC on the TV see's all my devices and everything works fine, but when I connect the android box anytime CEC see no devices and I am stuck with everything going through the TV speakers the TV does not see the receiver at all.
I have tried Turning off the ARC but still the problem persists, I have set the audio to PCM and the video to HDMI passthrough, the only thing I can think of is that in the options somewhere on the tunbux I changed the audio to 55.1 but now I cant find that option anywhere,
Is this tonbux box incompatible with my receiver and TV? dont knwo what else todo.
Any advice?
Kind Regards
Andrew
Sony BD player
SKU HD box
Any advice?
Kind Regards
Andrew
