Help Andriod box Help.
  • Start date Start date
A
Android Question
Guest
Hi guys,
this has been driving me nuts for months!!!
I got a Droidbox X7 from droidbox.co.uk
They loaded there own firmware on it, its VERY unstable and crashes a lot!
SPMC crashes quite a bit and Kodi as well.
Im trying to find a custom firmware to put on it which im guessing will be more stable than the one on it at the moment.
Problem is i have know idea what firmware to use
Its an unbranded box very similar to "Andoid 4.2.2 Quad Core TV Box CS918 Q7 T-R42 K-R42 MK888 MK888B MK918 RK3188" on amazon. (looks identical to that one, not sure if the chipset/hardware is different.
How can i find out what firmware to put on this?
Has anyone else got one of these?
Any help would be very much appreciated. IL happily pay someone a bit of cash to help me out.
thanks guys.
"DroidBox" a UK importer of unknown XBMC type devices from China. If the importer can't help you, there's not much else concrete that's available for them AFAIK. Problem is, if you try and flash the firmware from another device, such as the one on Amazon, you're very much on your own, and could even end-up with an irreparable brick and a void warranty.
