AndriOS ROM - Now experience iOS on your Funbook Pro ->
CustomROM|BeatsAudio|Bravia Engine|ICS 4.0.4|XLoud|Dolby| Beats Audio|SRS WOW|ClearBass Audio Effect|Adrenaline Boost| And Much More For Micromax Funbook Pro
Based on Stock ROM
Features -
-Pre-rooted
-Zipaligned all .apk files to optimize ram
-Hardware Acceleration Enabled
-Added Init.d Support
-iOS Keyboard
-iOS Notifications
-iOS Style Settings
-iOS Browser
-iOS Clock
-iOS Memo
-iOS Reminders
-iOS icons
-Replaced stock browser with iLauncher and modded heavily for performance
-Micromax AISHA Added
-Better Video Playback and Streaming
-Better Camera Image Quality
-Battery Tweaks (Immense battery backup)
-Adrenaline Boost script included
-Best Touch Response
-Performance Tweaks
-Net Speed Tweaks
-Tweaked Hosts File (No more advertisements)
-Ram Tweaks and Scripts
-Many Init.d tweaks
-Tons of build.prop Tweaks
-Directory Bind Pre-installed (Lets you move Games data to extsd)
-Apollo music player
-Bravia Engine
-ICS bar hide mod enabled
-Xloud Engine (AC!D Sound Mod)
-Dynamic Bass (AC!D Sound Mod)
-Dolby Sound System (AC!D Sound Mod)
-Beats Audio (AC!D Sound Mod)
-SRS WOW (AC!D Sound Mod)
-Clearbass (AC!D Sound Mod)
-Clearaudio+ (AC!D Sound Mod)
-Clearbase (AC!D Sound Mod)
-Replaced stock file explorer with ES File Explorer
-Removed all bloatware
-Ultra Smooth just like iOS
-Superchargerv6 script Included
- SD Card will work faster
- Added RAM Apps
-Chainfire 3d pre-loaded
- Much More !
_________________________________________________________________________________
How to Install this ROM?
*This ROM is flashable via CWM recovery
Note: Make a backup before flashing this ROM, just in case something goes wrong!!
1. Download AndriOSROM and Multi DPI Play Store for ICS.zip
2. Place these files on your external SD
3. Make sure you have installed CWM
4. Reboot to recovery
5. Wipe data/ Factory reset
6. Wipe Cache partition
7. Wipe dalvik cache in advanced menu
8. Choose the option Install zip from sd card and locate the zips and flash in this order -
(i)AndriOSROM
(iii)Multi-DPI-Store for ICS
9. Reboot system
10. Enjoy !
Downloads-
- AndriOSv1
- Multi DPI Play Store for ICS
FAQs
1) How to use Adrenaline Boost Script ? --> Download Terminal Emulator, Open it then type
2) How to Enable iOS Notifications ? --> Go to Settings-> System Settings -> Accessibility -> iPhone Notifications and turn it on ! Done !
3) How to use superchargerv6 script --> Open SManager, touch browse as root, hit back two times then go to system-->xbin-->superchargerv6.sh--> touch the su icon (make sure it is green) --> touch run. go through the script. Then choose the 9th option at the driver's console. Then choose the SuperClean and Restart Option. (you will have to run the script every time when you reboot but when you run first time it takes time to install but when u do it after reboot it will take u straight to driver's console and after that choose 33rd option and hit back.) Done !!
4) How to Enable ICS Soft Keys/Bar ? --> Go to Settings-> System Settings -> Display -> Then you will see fullscreen mod, tap it then change it to normal screen mod ! Done !
5) Background is black ? --> Lock an then unlock the screen then rotate the device so that its in portrait mode and then revert back to landscape mode ! Done !
6) Micromax AISHA not working ? --> Go to build.prop and change ro.product.model=GT-I9100, ro.product.brand=Samsung and ro.product.manufacturer=unknown to Funbook Pro (P500), Micromax and Micromax respectively (only change the letters after equal to '=') ! Done !
Big thanks to
- AC!D Sound Engine Team
- MyLifeRocks10 for Multi-DPI Play Store
- To all others whose apps and scripts i have used
Based on Stock ROM
Features -
-Pre-rooted
-iOS Keyboard
-iOS Notifications
-iOS Style Settings
-iOS Browser
-iOS Clock
-iOS Memo
-iOS Reminders
-iOS icons
-Performance Tweaks
-Net Speed Tweaks
-Many Init.d tweaks
-Bravia Engine
- Added RAM Apps
- Much More !
(i)AndriOSROM
9. Reboot system
10. Enjoy !
Downloads-
- AndriOSv1
FAQs
Code:
su
boost
Big thanks to
