Android 4.1.1 Keyboard Problem
mball1993
Hey guys, I am an IT Tech trying to work out a problem with a customers Android Tablet.
The brand is something I've never heard of called a 'Gemini'
Anyway, the onscreen keyboard doesn't activate when a type/search field has been tapped on the screen.
The OS is Android 4.1.1
He's other tablet which is the same works, but the screen is cracked so he bought another one of these hideous unresponsive pieces of crap.
Help?
Have you looked in the input settings?
You may want to try a alternate soft keyboard, Does the alternate provide better results?
Seeing as how you posted on the 1st and it is now the 6th I am guessing you probably solved the problem by now.
